jonny rotten
- Joined
- Jan 8, 2012
- 380
thinking of changing bellows are aftermarket ok or are they cheap quality.Will they were out faster?Is there a good aftermarket brand I should use? mercuiser/alpha 1 gen 1
imho, just use the proper oem part. drive shaft bellows aren't that much fun to R&R (semi labor intensive). sure would be a bummer to have to do the deed real soon again due to sub standard parts. aftermarket parts are copies of oem parts. who knows if they use the same materials to make them or not. probably not so they can make them cheaper...
while i don't know about the drive shaft bellows. i do know a buddy of mine replaced his exhaust bellows with a mallory copy. it failed within the same year of doing the replacement... that's a drag...
they can't make a bell housing shift shaft and shift lever either. i tried one of them and had to file to fit. finally gave up and got oem. fit like a glove. no mods...Used a GLM bellows ONCE, NEVER AGAIN!!! Far more difficult to fit, poorer quality and not that much cheaper. I have since only used Merc and not had any problems.
