Are all Mercruiser 3.0 front sump oil pans the same?
CLi87
The bottom of my oil pan is rusted and I'm looking to replace it and was wondering if all of the front sump oil pans are the same between years? Mine is a 2007 Merc 3.0 TKS
Bt Doctur
They should be with the exception of tin timing cover or plastic timing cover and oil pan gaskets
Scott06
if you have a steel timing cover would replace that at same time as there is a spot behind the balancer that doesn't get painted well at factory ... then rusts out
CLi87
Does it matter if it's a 2 piece RMS or 1 piece RMS? Same pan?
