WinnerCougar74
Thread starter- Joined
- May 12, 2020
- 315
I think instead of a switch to convert to eliminate the magna power I'll just do a jumper wire setup. As far as I can figure the blue ignition wire coming from the electrical block goes to the positive on the coil and the points connection on the distributor goes to the minus on the coil and you just add a automotive condenser to keep the points from burning. I think I can figure out a way to "unplug" the magna power and go automotive setup just in case the magna power fails on me out on the water.
