Are Force 70/90 crank cases interchangeable?
DaveyLC
I have a tired Force 90 (triple carb) mounted up to an inboard SportJet and I’ve just acquired a very tidy Force 70 (single carb) .
My question is are these blocks line bored or can the front/intake side be swapped? I’d like to use the crank, piston and cylinders from the 70 but the intake side from the 90.
Thanks!
Honorary Supreme Mariner
Check and see if driveshaft splines are the same.----Yes , they are line bored.
