Are Fuel Injectors and/or HPFP Compatible Between F115 and F250?
CLi87
Hey all, I have a 2012 Yamaha F115 that's been sitting for 8 years and the fuel system looked absolutely disgusting so I want to replace everything, I happen to have a parts 2014 Yamaha F250 engine sitting around that has brand new fuel injectors and HPFP and was wondering if I can use those parts on the F115? I'm thinking the fuel injectors probably won't work but the HPFP looks about the same with the same PSI specs but not sure about fuel volume, part number is different but only a few numbers off.
boscoe99
Different part numbers, different fuel pump and injectors.
PSI output from the pump depends upon the pressure regulator, not the pump.
