catfishhoward
- Joined
- Oct 9, 2009
- 136
I have 1990 20' bass buggy - 60 HP Johnson - I think it weighs around 1250 lbs but I cant find any manufacturing stickers (it might be 21').
I just moved to Florida and like going out for 3 days/2 nights which mean I have a lot of extra weight. I figure with batteries, gas, tackle, people and so on I have about 1300 lbs added to the boat/motor weight. The pictures you can see the water level in front is 12" from the top of the toon and the back the water level is 6" from the top and this was with about 600 lbs up front.
The floors rotten and the steering cable is rusted so I figured it is time to restore the boat but I really want to add more weight with built in storage so the weight might be closer to 1600 lbs when done. So 1600 lb + 1250 lb boat/motor = 2850 lb.
Will these 21" diameter toons be safe even if I can even out the weight from the front to the back trying to get the water line more even or is it supposed to be lower in the back? Or would it best best to add a 3rd center toon or should I replace the 21" with 25" toons? I want to be as safe as possible particularity since I'll be in salt water and you never know what kind of wave might hit you from other boat or barge waves.
