Are pre-1998 crownlines prone to rot?
alamantia
I see a clean looking 1996 CR225 not too far from me and the price seems good. I started doing some research on-line last night and I saw a post on another forum about staying away from pre-1998 crownlines. Something to do with the floors not being treated with marine grade wood. I have to ask, is that accurate information? Does anyone know for sure? I can't see why a boat company would use regular wood, but what do I know. Anyway, I would love to hear if anyone knows for sure or some first hand experience. I have been once bitten and twice shy when it comes to rot in older boats. I am not going through that again on my next boat.
smokeonthewater
It's made with water resistant glue so it doesn't delaminate when exposed to moisture... Has no bearing on rot tho
jkust
I second Smokeonthewater. Any boat is prone to rot if it has wood and if the owner allows water intrusion. What I will say about those late 90's early 2000's Crownlines is that their market counterparts were going to snap out carpet as a standard item but the Crownlines still stuck with glued down carpet. I see lots of beautiful early 2000's crownlines with glued down carpet which is a non-starter to me. Eventually it the glass floor became standard.
alamantia
I understand now. My wellcraft had the glues carpets and we did a lot of swimming when we were on the lake so naturally the floor got saturated and the carpet seemed to hold the water pretty good. I guess the only way to know for sure is for me to go see it and feel around the floor. I have read that some people use a moisture meter to check for rot but I don't really know thing one about that so I will just be doing the poke and feel method I guess.
jkust
Not that you do, but if you suspect wet/rotted stringers then taking core samples is really the way to be sure. I'd be interested to hear what the moisture meters shows.
All that aside, any lake boat can be kept from rotting with the right care. When I think a Crownline 225 that is only a 1998, I think that the first owner wasn't a rookie with a boat that was pretty expensive and he probably babied it for a good number of years. Even then, again just generalizing, the second owner would have likely paid some money for it as well. I know it only takes one bad owner, one season to do some damage.
milehighjc
As already stated, rot is largely a function of how well the boat was cared for. I bought a 1997 Crownie last fall, and was very concerned about rot. I started with the checklist that is stickied at the top of the forum... It was a great help for me - not just about rot by the way.
I "tap tested" around the motor mounts, walked every inch of floor that I could get my feet on, and then took a rubber mallet and tapped the entire floor looking for soft spots.
Mine seems to be solid. Im not exactly a seasoned veteran, but I did grow up around boats. This is the first one I have owned however. I think I had a couple of things going for me:
  • Previous owner was a meticulous 70+ year old man who had obviously cared for the boat well. It was garaged 15 of 17 years, and he took me through all the maintenance he had done in excruciating detail. He showed me every inspection point, and fluid reservoir - not that I necessarily needed that, but it was indicative that he had done the work, and actually did monitor things.
  • The boat was a Colorado boat... it is very dry here, technically we are a high desert. So even things that get wet dry out quickly. I took the boat out 4 times last fall after I bought it, would leave the cover off driving home, and the interior would be bone dry at the end of the day.
Core samples/Marine Survey is the way to go, but most owners are not going to let you core sample the boat before you buy it. Perhaps a putting contingency on the bill of sale? I had one on mine contingent on a satisfactory water test.
I helped my brother replace a floor in his '74 Silverline. Its possible, but not fun. Even putting the carpet back in was a joy - the glue fumes when getting it down under the bow gave me a 4 alarm headache for a day.
Good luck!
