Are SHIMS need on my 89 50HP Evinrude outboard
mrkingnh
Hello, I am about to reassemble my lower unit. I have purchased all of the internally moving parts inluding all bearings, gears, and seals. I am wondering if this particular drive shaft actually needs a SHIM. The exploded views I have seen, show a SHIM, but when I go to order one, the selections start for 60HP and up to 2500HP? Does anyone know what size (if necessary) shim I need?
Motor: E50TLCEC
1989 50 HP Evinrude
seahorse5
Re: Are SHIMS need on my 89 50HP Evinrude outboard
To know what shims you need, the driveshaft and pinion gear have to be installed in a special fixture with the correct adapters to measure the height from the machined surface of the pinion gear to the inside flange of the driveshaft bearing carrier. By following the steps in the service manual and using the correct shimming gauge part number, you can calculate the total amount of shims required.
The special tools are very expensive so it would be best to have an authorized dealer do the shimmiing procedure for you, then you can install the gearcase parts on your own, as long as you follow the manual.
boobie
Agree + 1.............
