Are Surface-Gap Sparks Plugs & Standard-Gap Plugs Interchangeable on a 115HP V4?
BeaterSkeeter
I have a Johnson 115 V4 - I was told it was an 84 - the motor has a sticker that says use champion UL77V plugs which corresponds to an '85 from the spark plug lists I looked at.
http://www.iboats.com/Johnson-Champ...6300814--session_id.720120536--view_id.669920
The motor currently has the UL77V plugs in it. Champion describes this as a race plug with unique operating characteristics and requirements. Also says it's prone to carbon fouling.
http://www.championsparkplugs.com/more_info.asp?AAIA=&pid=4436
The other plug listed for this motor for 75-84 is a champion QL77JC4, which is a resistor plug with a standard adjustable gap.
http://www.championsparkplugs.com/more_info.asp?AAIA=&pid=8807
Are these plugs interchangeable since they are in the same heat range? The electrode on the standard plug can't hit the top of the piston domes on the special V-4 pistons, can it? That would seem like an awfully narrow squish band if that were the case. Should I just set it up with the same .30 gap as all the others? I'm just curious as to why the only plug suggested for use in this motor would be a race plug. To me it seems these plugs should be interchangeable but I figure why not ask here and see if someone has the knowledge to share. Thanks!
Jlawsen
Re: Are Surface-Gap Sparks Plugs & Standard-Gap Plugs Interchangeable on a 115HP V4?
The two strokes that I deal with actually do quite well on surface gap plugs. I'd stick with them if it were me.
TrueNorthist
I prefer the surface gap plugs as they seem to work better for my 6hp, both for trolling and WOT. I do not notice any carbon problems, but I routinely pull the plugs after each trip out and clean them with carb and choke spray cleaner. Makes a plug last a lot longer. And you will not damage the piston using adjustable gap plugs as long as they have the correct thread reach.
V153
It's rumored that the surface gap plugs are better for top end. Though most of the go fast OMC boys I know run NGK fine wire Irridiums.
TrueNorthist
The OP might want to read here. I had noticed a decrease in "sneezing" too after switching to surface gap plugs but was afraid to say that without some sort of proof. It looks like the increased air-gap acts as increased resistance which in turn gives a better spark on CD ignitions. I think I will try the NGK resistor types next time and see if that is even better. I am running Champion L76V plugs right now and NGK is usually a better plug but who knows...
