Are the 2003 Mercury 60hp 3cyl Bigfoot known to shake?
jeep187
I have a 2003 Mercury 60hp 3cyl Bigfoot.
When i have the motor raised in shallow water or going slow the motor shakes.
It is real noticable when I have the hose hooked to the earmuffs flushing out the motor.
Is this normal or should it be fixed?
Thanks in advance
hamit59
Re: Are the 2003 Mercury 60hp 3cyl Bigfoot known to shake?
what motor is it 4 stroke 2 stroke. What's the plugs look like ? check for spark and all cylinders. check compression. It should not shake much.
Post back with what you find .
Dunaruna
It's a 2 stroke oil injected. In 2003, all 4 strokes were 4 cyl EFI.
Probably a carb issue. When was the last time they were cleaned/rebuilt?
jeep187
They were just cleaned and rebuilt about a month ago by a mercury dealer. Yes is is a 2 stroke oil injected.
hamit59
we need the compression numbers
what did the spark test tell spark jumping 7/16 on all cylinders?
If that's all good then I would say you still have carb issues.
