Are these motor's compatable?
scrit9mm
Are parts from these motors compatable? What, if any parts are interchangable?
Model # 25R73A
Serial # E3789899
and
Model # FD-20C
Serial #12645589
I am purchasing the top one today which is a 25 Johnson. The bottom one I already own and is in-operable due to physcial damage, but it does have good parts on it, its a 20 Johnson.
kbait
Re: Are these motor's compatable?
25 is a '73,
20 is a '66.
Magneto's are definitely different as the 20 has coils/points under flywheel, and the 25 has points under/coils external.
Lower unit's may swap over.. more folks will chime in with total expertise!
What exactly do you need for the 20hp from the 25??
scrit9mm
Nothing that I know of right now because I have yet to pick up the 25 horse. For future reference just in case a bolt is needed or something else that.
