gustro
Thread starter- Joined
- Nov 30, 2010
- 21
Taking this one to you pros out there.
I have a 1990 Baja with the GM 4.3 and a simple two barrel carb. When I purchased the boat it only had the mesh fuel filter in the carb, no canister filter with means of water seperation. I installed a canister filter and replaced the mesh filter that goes in the carb housing. The canister filter gets replaced yearly yet I got enough sediment in my mesh filter to cause a high idle stall (about 4 seasons on the new mesh filter) so I replaced the mesh filter again. The questions is "do I need the mesh fiilter and will the carb pass the sediment w/o issues or damage"?
Kind of a pain to get at the mesh filter and would like to keep it out of the system.
