Aristocraft 19 Steering Cable
Day Dreamer
Anyone know what the length of a steering cable for a 19 would be. I didn't want to rip it out intil I had the replacement in hand.
Thanks!
Chuck
aristocraft
Re: Aristocraft 19 Steering Cable
Chuck, just replied to your email as well, however for the knowledge of everyone i wanted to reply here as well. You will need a 17foot steering system. MAKE SURE you tie a small rope through the eye of the old cable before you pull it out through the tube or it will be hell to reinstall the new one. then as you are installing the new one MAKE SURE the cable end is pulled all the way in so the end is as short as possible if that makes sense. tie the rope that you pulled through the tube, through the end of the new cable, and have some pull the rope as you push the cable, working it back and forth and it will magically come out the other side. best of luck
