Arneson surface drives
Status
Not open for further replies.
scoutabout
Re: Arneson surface drives
You guys need to check this one out: Surfacing I/O thing
I have been watching it for a couple of years. I'd sure like to see a drive without two 90 degree turns . . . :rolleyes: With a biiiiiig swimstep, could even be a farely clean installation.
This is a fascinating piece of engineering, QC. Really elegant in its simplicity. I take it though it could not be a bolt on for a conventional i/o as you would then have no gearbox?
Willyclay
Seems to me that a pair of surface drive units on an "offshore sportfisher" will provide lots of opportunity for snagged lines and lost fish. Good luck.
QC
Correct, needs a clutch and reverse mechanism, basically a standard Marine tranny, Arneson would need the same, so did the old Merc TRS for that matter. I absolutely LOVE the straight thru driveline. No directional changes of power, typically eats 20 horsepower out of a standard I/O. Almost the simplicity of a direct drive inboard, but trimmable.
Don't Outboards pose the same problem? With that said, not all boats are fishing boats. Not a lot of I/Os in fish boats either, but they seem to sell OK. I agree, lot of stuff back there, that's why I think it is for go fasts and family boats with a big swimstep.
Gben
Been kicking around boats in florida for 40 years. Surface drives : pros : efficient, low draft. Cons : startup torque, maintenance on exposed parts.
We see a LOT of exotic boats in the miami \ft Lauderdale area mostly areneson and mercury surface drives ( the less I say about 4 or more large out boards the less trouble I'll get into) and rarely a buzzi or spd....they all do a good job, maintenance being the Achilles heel...one of the best surface drives I have personally worked with is the power vent system on a don smith 45 , really works, 40+ knots on twin 400hp volvos, one outboard bearing and good economy.... I have no idea why the system never took off except maybe its best with a stern designed for it...they stopped making them around 2008-9 and if you can find one for less than $250k jump on it
Gben
Its not so much snagged line as backing down, surface drives don't love that
Status
