further
- Joined
- Jun 18, 2009
- 1,038
I'm dealing with a stripped hex drain plug in the lower unit and four very stubborn round flat head screws at the t-stat housing and the upper plug (which i just got out using the impact driver - putting in a tell tale). I got an easy out to try on the LU but will do that after I fog the engine for winterizing this weekend. I'm fussing with the four screws on the t-stat housing - got two loose with the impact driver but the other two won't budge - feel like i might damage something with the amount of times and force i need to wack it with. I've soaked them in wd-40 and will let sit in the motor up overnight and reapply again tomorrow before I try again. Question is i've heard of guys here recommending heat. I'm very new to all this and figuring out as i go, can I use a blow torch to apply heat and how much does it need? Sorry if this sounds stupid, but i've never done this before and would like to get these out finally. a 20 minute project always turns out to be a multi-day, multi $$ fiasco. gotta love it!!
Thanks everyone.
Thanks everyone.
