Ask The Experts | Four Cycle Engine Oil Update
toneeees
Administrator
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]By now, you're probably aware that automotive lubricants aren't adequate for use in your four-stroke outboard, and that you should look for marine-grade oils displaying the National Marine Manufacturers Association® (NMMA®) FC-W® (Four-Stroke Cycle, Water-Cooled Gasoline Engine Lubricant) certification label.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]art3_1.jpgHave you ever considered what that FC-W® rating really means? We at Yamaha wanted you know because our findings gave us a new appreciation for all the behind-the-scenes work necessary to prove an oil is worthy of the FC-W® approval.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]This gets a little techy but it's great information so you use the right oil for your engine.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]Dozens of Tests
Using the NMMA® FC-W® Certification Procedure Manual as the guide, a four-stroke oil must successfully complete tests in 12 major categories, including all the steps and tests within each of the categories, to be eligible for FC-W® certification.
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]Here are the categories and brief insights into the specific nature of the individual evaluations:[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]A. Identification Tests
Identification tests, using ASTM International standards, define the test oil�s unique characteristics, defining precisely what makes this oil different than other lubricants.
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]Note that 10 tests comprise the Identification portion of the FC-W® protocol.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]Kinematic Viscosity @ 40C/104F (ASTM D445)
Viscosity Index (ASTM D2270)
Specific Gravity (ASTM D1298 or D4052)
Total Base Number (ASTM D2896)
Total Acid Number (ASTM D664)
Elemental Analysis (ASTM D4951, D4927, D4628 or D5185)
Sulfur Content (ASTM D5453, D2622, D4294 or D6443)
Nitrogen Content (ASTM D5291 or D5762)
IR Spectrum (ASTM E168)
SAE Viscosity Grade (SAE J300)
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]B. Kinematic Viscosity @ 100C/212F
Kinematic viscosity loosely translates into how thick the oil is, at a specific temperature, when moving (via gravity in the test). This test determines the oils thickness (viscosity) at 100C/212F by measuring how long it takes the oil to drip through a calibrated glass laboratory fixture.
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]C. Cold Crank Simulator Viscosity
As the temperature drops, oil tends to thicken and flow slower than it would at normal engine operating temperatures. This segment of the evaluation simulates the effects of low temps (-5C/23F to -35C/-31F) on an oil's ability to provide adequate engine bearing lubrication when starting the engine in cold conditions.
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]D. MRV-TP1 Viscosity
Starting at 80C/176F, an oil sample is cooled to predetermined temperatures where oil failures typically occur. A complex rotor/stator fixture measures the oil's resistance to turning motion, to determine how well the oil will flow through the engine's oil pump at cold temperatures.
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]E. Foam, Sequence I, II and III
This test determines the foaming characteristics of lubricating oils at 24C/75.2F and 93.5C/200.3F by blowing air through the oil at specific temperatures. Foaming (air/oil mix) can prevent the oil pump from circulating the oil through the engine, resulting in lubrication-deprived components, and eventual engine failure.
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]F. Foam/Aeration, Sequence IV
Oil foaming at high temperatures creates a host of issues, including lack of internal component lubrication, inability of the oil pump to circulate foamy oil, as well as oil system overflow from the increased volume of foaming oil. Conducted at 150C/302F, this test quantifies an oil's foaming characteristics and performance at elevated temperatures.
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]G. Shear Stability
Predicting the decrease in an oil's viscosity when its polymer ingredients break down under shear stress indicates how the oil is going to perform in the real world.
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]H. High Temperature High Shear Viscosity
A key property of an engine lubricant is its High Temperature High Shear (HTHS) viscosity - the ability of an oil to maintain sufficient viscosity at high temperatures (150C/302F). This indicates if an oil is likely to provide proper lubrication to critical parts of the engine, such as the piston ring-to-cylinder wall contact area, crankshaft bearings, connecting rod bearings, and camshaft bearings.
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]I. FC-W® Rust (Salt Fog Test/SFT)
Marine engines operate in a damp, wet environment - it goes with the territory. The last thing we want is rust forming inside the engine; this test tells us how well a candidate oil protects cylinder bores from corrosion and rust.
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]J. Noack Volatility
As operating temperatures increase, lighter portions of an oil's formulation are likely to evaporate, leaving behind thicker, heavier parts of the oil. The result is reduced engine performance and reduced fuel economy because of the extra effort required for the moving parts to slog through the remaining higher-viscosity oil. This exercise determines the lubricant's evaporation rates at given temperatures to predict the oil's performance in real life.
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]K. Filter Plugging (EOFT)
This test replicates running a new engine briefly, then storing the engine for an extended period, with a bit of water and combustion by-products suspended in the oil - then, to what degree will the slightly contaminated oil clog up the oil filter when you restart the engine.
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]L. Yamaha 115 Hp General Performance Engine Test (GPET)
This separates the players from the wanna-be's our favorite test by far.
[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]art3_2.jpgUsing a brand-new Yamaha 115 hp four-stroke outboard (powerhead) outfitted with a cut-down propeller to simulate a load, the engine is run in a test tank at specific rpms for predetermined lengths of time.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]Oil samples are taken at requisite intervals to monitor the oil's dilution levels, and the engine is disassembled at the end of the test to inspect individual components for lubrication-related wear or damage.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]And this is the condensed, easy-to-read version; each test is thoroughly documented to ensure only the best oils make the cut.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]Every engine manufacturer has their own proprietary lubricant blends, and we strongly recommend using the lubricants specified in your engine's owner's manual.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]Yamaha four-stroke outboards reach peak performance with Yamalube oils and lubricants, for example.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]Don't cut corners and put lower-quality, non-certified oil in your four-stroke outboard. The few bucks you might save today can negatively impact your boating experience and your wallet in the future.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif]Get the best. Your outboard deserves it.[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif][EDITOR'S NOTE] Find the marine engine oil at iboats.com[/FONT]
[FONT=Trebuchet MS, Lucida Grande, Arial, sans-serif] Article courtesy of Yamaha outboards. For additional information on Yamaha boating, visit yamahaoutboards.com.[/FONT]
