LandOfRath
Thread starter- Joined
- May 24, 2021
- 31
I have a 2000 Mercruiser Alpha Gen2 with stiff steering, I have unhooked the cable and it moves freely. The Drive is hard to move by hand with cable unhooked. After two days of spraying the upper and lower pivot points on the gimbal ring it is starting to loosen up but I would really like to add a grease zerk and get some good quality grease in there to see if I can get it loosened up through the summer then take it apart this next winter for some maintenance.
I have found the Sticky on how to install it but in the photos it looks slightly different than mine having a steel plate behind the two bolts, guessing its an alpha gen 1 in the photos? are all the measurements the same on all the alphas? And can you add one the the lower pivot point as well?
Thank you.
Thank you.
