Assembly of lower unit after water pump replacement
PS
I can't seem to get lower unit to fit up tight so that I can put the bolts back on. It get within .5 inches and seems to be stuck somewhere around the drive shaft. The drive shaft does have the spring loaded pin that could be causing the difficulties. Transom assembly is ser #6798040 I beleive this is an Alpha 1 (R drive)? Any thoughts?
