artificialreef
Thread starter- Joined
- Feb 21, 2009
- 504
Hello folks. I am still trying to tune my starboard motor after replacing points, plugs, condenser, wires, cap, rotor. I got the dwell set right at 30 degrees. Now trying to set the timing idling at 700 rpms. Problem is i put the one lead (yellow on snapon mt416) on the negative of the coil and the other (black)to a good ground and the rpm gauge reads 20,000 rpms. I know what a decent idle sounds like and it is definately not 20,000. It sounds nice like 700. But the timing is way off. No backfires.
Question 1: What would make the gauge read 20,000 when it sounds like 700.
Question 2: If the gauge is bogus why is it when i bring the timing anywhere near the 4 to 8 degrees specked it runs like garbage.
Thanks for your gracious assistance.
1983 26 Tiara w/twin 470 3.7 mercruisers
