highpowerdad
- Joined
- Feb 5, 2020
- 113
Four Winns with a 5.0GXI-e, SX drive, So, boat was FINE just a couple of days ago, all around the lake...but tonight, start it up and after a minute I get a little bit of what sounds like a belt squeak. Don't think much of it and figure it will go away in a minute...It has a similar noise every now and then...well it didn't and the engine overheated after a few minutes of no wake speed and a minute at 3000rpm, buzzer went off and it was at ~240F...I shut it down, checked for weeds etc, in the water intake - nothing - and let it cool for 15 min, started it back up and limped back to the dock...had to "rest" half way there when it hit 240F again. So...I assume the squeaking noise was the impeller running dry, so even though I will assume the impeller is shot, it probably was not the problem, just the fall out of another problem...so what should I look for...if I just put a new impeller in it, I will probably just burn it up... ALSO, I assume the buzzer sounds long before real damage is done...but it would be nice to hear that from one of the pros here...ah...this boat is being really difficult...
thanks
highpowerdad
thanks
highpowerdad
