At my wits end
Gary H NC
I did the compression test 141,141,147,145,151,151
Seafoam is good to clean the pistons if you mix it heavy...Done that before but not your problem.
Look on the transom bracket for a serial number plate..
merc850
I think your problem is somebody damaged the carbs - the JB weld is plugging up the welch plug access to the internal passages. New or undamaged carbs might solve the problems.
chevysford
I’m thinking the same thing. Any recommendations??
