Yacht Dr.
- Joined
- Feb 26, 2005
- 5,581
Re: At the gelcoat stage - help needed!!!
Outback Jack;3483300YD Do you use a refinishing da something less aggressive then the regular da ?[/QUOTE said:Nope ..
I use a 6" porter cable and a 5" air Dynabrade DA. follow up with wetsanding the radi and the other surfaces.
The trick is the "guide coats". I use Dykem or a marker with an acetone rag. You will never go through if you use Guide Coats ( well.. not never but hardly ever) .
Guide coats are your friend .. use them as much as you can in your heavy grits. Beyond 400 there kinda moot.
YD.
