morebass 17
- Joined
- Mar 25, 2011
- 223
Re: At the gelcoat stage - help needed!!!
Thats a much better way Ondarvr, I will go for two thicker coats then with the second coat containing wax.
How strict is the 18 mils though?, As I am basically a novice sprayer I don't think I will be able to achieve a uniform thickness throughout, also should all curves,corners be a little thicker as these will get hit harder on the sanding step?
7. Spray 1st coat with no additives, just acetone for thinning, amount of thinning will vary depending on the viscosity. I plan on a 10 mil thickness with each coat, and overall thickness of about 30 - 35 mil before any sanding.
8. Folowing day, spray another coat exactly the same as the last, with no additives.
9. Folowing day, spray my final coat with a wax additive that will be recomended by my resin supplier. Exact ratio still uncertain but in the region of about 10%.
All of these can be done in the same day back to back.
Gel coat needs to be sprayed about 18Mils or so for it to cure well, so two slightly thicker layers will be fine if you do them separately.
By the time you spray 18mils and clean the gun it will have gelled enough for you spray more over it without sagging, so you can do it all at one time if want.
