ate 800 stringer drive -mechanical shift-gear ratios?
Boat Doctor1
I have a omc od with upper drive bad it is a ford v8 302 engine (omc) and a 21-16 gear ratio- i have located a upper that is a ratio of 21--20(3.8l) and another with a ratio of 21--19 (4.3 l) What difference will either actually make??if installed inplace of the v8(21-16) ?? the 21-20 is a almost a 1-1 ratio & maybe the 21-19 maybe better?? yet couldnt I just change the prop for ratio differences? or??
Howard Sterndrive
start with the basics... alt belt slipping? battery terminals and ground connections clean and tight. visual check of connections at ignition switch and other easily accessible spots.
