Re: Attaching rotary steering to the outboard
*edit* - oops, typed too soon. Cannondale is right and I was wrong to say it could easily work. I see now that you have no way to run the cable through the transom clamps. Plus you need an intermediate rod to connect between the cable and motor to give the proper throw and range of motion. Here's a (poor) pic of the setup on my old tinny.
Note both the intermediate rod and the fact that the cable passes through a dedicated tube between the outboard clamps to anchor it so that when you turn the wheel, the motor will turn and not just shift the cable around.
Now, if you got that intermediate rod and found a way to anchor the cable securely, it might work. You'd want to be real sure of it though before heading out on the water...
**edit the edit!** :facepalm:
Ok - I found a better pic of the setup on another boat...
