I have a 2 story house which I need some help with attic ventilation.. My house does not have any soffit overhangs on the front or back. I have 5 roof vents that were cut in with my new roof, and without overhangs and soffit vents the roofer recommended vented drip edge to try and get some intake into the attic. I have short walls on the outside walls with sloped ceilings in the bedroom that are 2x4 rafters. I purchased styro-foam baffles to install to allow air flow. I went into my attic and removed the insulation that went down the roof pitch and blocked my new vented drip edges..While I have all that insulation out, I figured my unrestricted air flow would help cool the attic in the summer, but it let more heat into the house then cool my attic...Being the airflow is minimal if any from my drip edge venting, Im tossing around the idea of completely sealing the (approx) 4ft of sloped ceiling space that heats the bedrooms off with spray insulation making it airtight and should minimize the heat coming into the bedrooms, and adding powered vents on the sides of the house for intake ... Somehow I need the increase the air intake and reduce the heat transfer that comes into the bedrooms through these 4ft sloped walls in my bedrooms. Ive also tossed around the idea of using the styrofoam baffles and cutting 2" pink foam to slide down the sloped ceilings, but the R value isnt that great for the styrofoam... any ideas or thoughts?
