Attwood bilge switch
bones774
I have an Attwood float switch in my bilge, it several years old, I can't tell the model number it doesn't seem to be present on unit. Anyway is the float level adjustable? with cover removed and manually lifting the float the pump turns on, though it seems like I have to lift it higher than it would float if cover were on and during some storms this season my bilge was filled with water because it did not turn on automatically.Or just buy a new one?
Thanks
Fireman431
Re: Attwood bilge switch
Some newer models are adjustable. There will be a screw on top or on the back. If it's older and it's operation is questionable, get a new one. It's a $15 part. How many would you be able to buy with that $500 insurance deductible when the boat floods?
bones774
Yup, you're right, i just hate to be another cog in this disposable world if the switch can be repaired
Is there a better quality switch out there?
Fireman431
Pretty much anything by Rule or Attwood will be good. They have been in the business a long time. Just make sure there isn't any crap in the bilge and it's range of motion isn't hampered. Test monthly by plugging the garboard and filling the bilge with water.
NYBo
Um, I don't think actually filling the bilge would be a good idea, and the (engine's) starter and other electrics would probably agree.:eek:
But if the float switch is properly positioned, putting enough water in the bilge to trip the switch would be a good idea.
Fireman431
You knew what I meant :rolleyes:
Fill the bilge with enough water to make sure the switch activates properly without flooding the engine electrical components with water....
Didn't think I'd have to spell it out so discriptively...
