I did the same but drilled holes and bolted the new one on.I would fire up the die grinder with a cut-off wheel and weld a different actuator
I am just in the process of converting. Took a little while to drill the hole through the entire surge slider. One 1/2 inch bolt should cover the weight of my 4000lb Thompson 240 with 36000lbs of shear strength at each shear location. This is based on the specs of a standard steel bolt shear strength being 60% of max tensile strength of 70 x 10^3 psi.I converted to all electric brakes.
My surge brake system needed constant repairs and rust in the master cylinder was the final straw. Plus I hated the slapping noise every time I stopped or accelerated.
After the conversion, I ran a bolt through the actuator to stop it from sliding.
The electric brakes work great and with my factory brake controller, it's integrated into my truck's braking system.
Suggest you rethink your math.I am just in the process of converting. Took a little while to drill the hole through the entire surge slider. One 1/2 inch bolt should cover the weight of my 4000lb Thompson 240 with 36000lbs of shear strength at each shear location. This is based on the specs of a standard steel bolt shear strength being 60% of max tensile strength of 70 x 10^3 psi.
Well, it was exaggerated definitely. So each shear location, would take 7000+-. Which is 28000lbs, which gives fairly large safety factor, especially since the brakes will reduce the load "instantaneously" as the load would shift.Suggest you rethink your math.
Don’t see where you converted the load to pounds per square inch. Don’t see where you accounted for acceleration and deceleration induced loads
I buy 5/8”, grade 8 bolts by the pound because I shear them on a regular basis mowing the back field with a bush hog
I would highly recommend 3, 1/2” , grade 8 bolts![]()
Going heavy is an easy way to increase the safety factor too.Well, it was exaggerated definitely. So each shear location, would take 7000+-. Which is 28000lbs, which gives fairly large safety factor, especially since the brakes will reduce the load "instantaneously" as the load would shift.
You don’t have a clue. This is how people get hurt…Well, it was exaggerated definitely. So each shear location, would take 7000+-. Which is 28000lbs, which gives fairly large safety factor, especially since the brakes will reduce the load "instantaneously" as the load would shift.
(edited) never mind, thought you were the OPI am just in the process of converting. Took a little while to drill the hole through the entire surge slider. One 1/2 inch bolt should cover the weight of my 4000lb Thompson 240 with 36000lbs of shear strength at each shear location. This is based on the specs of a standard steel bolt shear strength being 60% of max tensile strength of 70 x 10^3 psi.
Fleet Brake sells electric backing plates for $50 each. Looks like under $150 total conversion adding the connectors and other materials.
Hopefully they hold up to corrosion as I am a regular salt water boater out in St. Margaret's Bay.
