ehenry
Thread starter- Joined
- Jan 6, 2002
- 2,393
I've completely over hauled the A/C system in my 86 Toyota truck. I've replace everything from the condensor back.....condensor, receiver filter, compressor, evaporator core, expansion valve, pressure switch, replaced every o-ring...Everything ! I put 8 ounces of pag-48 oil in the compressor and charged the unit with 134a freon. Both low and high pressure readings are with in spec according to my shop manual for the truck which are 28/30 on the low side and 275/300 on the high side. The coldest the air will get coming out of the dash vent is 40 degrees. With the old R-12 in the system it would blow 32 degree air. In my car, wifes truck, and sons which are late model 134a factory systems the air gets colder than my little truck......anyone got any ideas or is this the best yall figure i'm going to get.
