Auto bilge pump float not working. Where do i start?
beason
1999 sea ray 180 with merc 3.0 and alpha 1.
I was looking for a leak, and put some water in the rear of the bilge area. I noticed that the float switch never turned on the bilge pump. I checked the movement of the float, and it moved freely. Where do i start troubleshooting? Is it worth chasing down a problem, or do i just replace it? If i replace it, how is it mounted, and how do i remove it? Its pretty hard to get to, directly under the engine.
thanks!
NYBo
Re: Auto bilge pump float not working. Where do i start?
Is there a separate fuse for the float switch circuit? (Hint: there should be.) If not, how is the fuse for the entire bilge pump setup?
Ayuh,... Is there power goin' to it,..??
beason
The bilge works if i flip the switch. It just doesnt with the float.
I didnt check the specific fuse, but i did glance over them and didnt see any blown. I will check again.
Its a 2 wire switch right? so power in, switch, power out to pump?
I will check fuses, and dig out the test light next time i bring it home.
If it is borked, how is it mounted? how do i replace?
NYBo
Yes, there should be two brown wires, on e in and one out. The "in" wire should be connected directly to a battery positive terminal, hopefully with a fuse between the battery and the float switch.
We can't tell you exactly how yours is mounted. Mine is mounted with two screws.
beason
just wanted to update this since i got so much useful help from you guys.
I finally got the boat back home, and started prepping for this season. I unhooked the float and connected it to my voltage tester. it would sporadically work. So i knew i had to replace it.
I then noticed that the hot wire to the switch wasnt hot. I searched and searched for the other end of that wire, and never could find it, or a fuse feeding it.
I gave up and ran a new wire from the battery, through a waterproof spade fuse holder to the switch, and then to the pump. Mounted it with marine silicone on the screws and its all working as it should how.
I also installed a battery maintainer, and replaced the prop!!
i feel like a real boat owner now!
