kenojim
Thread starter- Joined
- Jul 29, 2021
- 24
I have two 12v batteries,..
1 House and 1 for minn Kota TM.
I have a yandina combiner 100 that automatically allows outboard alternator to charge TM battery as well as house battery.. No manual switches it's all automatic.
I left boat in garage all week with TM battery connected to 5amp battery charger / maintainer.
The 5 amp kick isn't enough to keep the combiner switch closed, so it cycles or gets in to a cycle of sharing the charge then switch opens.
The switch opens and closes maybe 2 or 3 times every 15 minutes.
Since then the combiner has not worked properly. When on the water and outboard running the combiner chatters loudly.. Sounds like a deck of cards being shuffled aggressively...
Green light also won't stay on and red "overload" light comes on and stays on even when no charge being applied to both batteries.
Anyone else run in to this? Did I burn up the switch with just a 5amp charger? Would a 10amp stronger charge of made a difference?
I'm going to replace the combiner with a new one, was thinking of putting a manual 12v switch on the TM side hot wire to force the batteries to stay separated while being charged by battery charger...
Appreciate any thoughts
