beckoning
- Joined
- Dec 15, 2010
- 171
I have 2 bilge pumps: one manual and one automatic for which I no longer have the directions or even know the brand (probably a Rule). The automatic bilge pump cycles every 3 minutes to check for water. I have very limited space in the bilge, and cannot screw the automatic pump to the hull, so it sits on its side. That may be the problem to why it doesn't not sense water even when the bilge is full.
QUESTION: Does the internal float in an automatic bilge pump require that the pump be vertical (top up) to work? Mine sits on its side and does not activate to pump out water. If it needs to be vertical, how to secure it at the bottom of the bilge without screwing it into the aluminum hull? If I wedge it in with something, the vibrations from the boat in motion will dislodge the wedge. Your ideas on how to secure the pump into a vertical position in the bilge?
