Keith7481
- Joined
- Aug 21, 2005
- 129
I've been reading through the forum looking at some of the discussions about float switches and bilge pumps with the built in float switch. I recently picked up my boat from my mechanic who I had doing some minor work and had asked him to look at the float switch that I thought was sticking 'on'. He stated he tested it and found it worked correctly, he had filled the bilge etc. to test it. When I brought the boat home, I had to hook up the #1 battery, which I had disconnected because of my fear that the switch was sticking on and going to run the battery down, I trailer the boat. With the ground wire connected, I touched the red lead to the positive terminal and saw a small spark, but the pump did not run. As my battery selector switch was set to off, I was surprised. There was no water in the bilge, and as far as I know, nothing else should be able to run off the #1 battery beside the bilge pump via the float switch. So, I'm thinking my mechanic is wrong, or the there is always a small current going to the float switch when off, or I have an electrical problem with something else. I"ve read the posts on doing the battery drain tests and have the multimeter ready, just wondering if anyone had any insights on why the float switch might draw power when the pump is not running? Thanks in advance.
Keith
Keith
