pecheux
Thread starter- Joined
- Jun 9, 2006
- 1,200
good day, My 15 hp Force OB's lower unit does take in approx 1 soup spoon full of water per season. I have decided to change the LU oil twice per season since a pressure test did not show any leak. In the meantime the OB is in storage for the winter months and as preventive maintenance I have added a mixture (50/50) or LU oil with automotive 'transmission stop leak" additive hoping the seal may swollen a bit during the winter season, then I plan to change the LU oil again in the spring prior to using the motor. Question is: was that a good idea ? Or should I dump the mixture and replace with 100% LU oil right now ?
Thank you.
Thank you.
