Automotive Equivalents
domaotc
I have an Autozone near me and was hoping someone could suggest automotive equivalents to the following items:
OMC Gasket Sealing Compound
OMC Gel Seal
OMC Adhesive "M"
OMC Cleaning Solvent
I found the choices for Gel Seal particularly confusing the last time I was there.
Thanks
what are you sealing?
most of the gasket sealing compounds are permatex #3. most cleaning solvents are brake cleaner
the OMC gel seal is loc-tite anerobic sealer
The OMC adhseive "M" is Scotchgrip 3M 847
domaotc
That for all the responses. It's a 1982 9.9hp yachtwin I'm reassembling.
HighTrim
I have found no equal for the OMC Gasket Sealing Compound. I like it, get the can with the brush built in.
For the Gel Seal, as mentioned, Loc Tite 518, or the equivalent Permatex 518
Type M is now 3M 847, available at many locations. Not cheap though, but works very well.
The parts cleaner/brake cleaner is the easy one!
F_R
Slight typo there by High Trim. "Type M is not 3M 847" should be "is now". At least I trust that is what he meant to say. Sorry Chris if I'm over-assuming. I really do respect what you have to say.
HighTrim
Thanks Frank!!! I edited it. I hope you respect what I have to say, cause I learned it all from you.
Cheers Thanks.
