Bansheex13
- Joined
- Jun 18, 2008
- 72
I know to use brass freeze plugs,but is it ok to use auto gaskets for a boat that doesn't ever touch salt water?
fresh water cooled eninges are no different than a car eninge running water to cool it, even freeze plug in freash water woulod work just fine, after all what does a car run to cool it air???? car engine sit in water all day long for years and years, if you are in salt water thats a different thing
they say you can pull a junk yard motor and put all outside marine stuff on and you can run it just fine
Who's 'they'.
And did 'they' tell you that a year later 'they' had to go get another engine?
Automototive engines do NOT last under marine loads.
Sorry but no, they will rust away. In a car, if you put plain water in it, the water will eventually reach a point of chemical inactivity because the minerals/chemicals react with the metal until they are exhausted and then it stops. In a fresh water boat you are constantly changing the water and the chemical process continues until something is eaten away.
Who's 'they'.
Who's 'they'.
are you nuts or what???????? car engines was running on pure water and not rusting out before you and i was born, use your head man for something besides a hat rack, do you think anti- freeze has been around for oh 150 yrs?????? when i use 18 we used pure water, in all cars , yes anything will rust but give a good reason,
Well, I have the original OMC shop manuel & it specifically states to use a marine head gasket & not to use an automotive head gasket. When I pulled the head off of my '87 3.0 about 5 years ago to have it magnafluxed & planed, I used a head gasket for marine use, which by the way the shop that did the work also recommended. And I haven't had a problem with it. You do what you want, but I will use what the manufacturer recommends & what the people that do that kind of work everyday recommend.Yes you can. Even the head gasket can be automotive - just use one of the newer composite material head gaskets and you will be fine.
well i have worked on several model A fords that just kept running hot after pulling the water pump apart we would find no fins left on the cast impeller. no to mention these old engines had low compression and after a few years of straight water they would have head gasket problems all that said would you really want to have to do the job again over a few hundred dollars?are you nuts or what???????? car engines was running on pure water and not rusting out before you and i was born, use your head man for something besides a hat rack, do you think anti- freeze has been around for oh 150 yrs?????? when i use 18 we used pure water, in all cars , yes anything will rust but give a good reason,
OMC didn't recommend anything. All they said in the shop manuel was not to use an automotive head gasket. And as far as people like me smart guy, I've been keeping the same boat running since '92 with the original engine & outdrive. And never had to have a rebuild on either one. And no dealer wrenches for me either, or ever did.And what is it that the manufacturer recommends? They recommend that you use THEIR part! How convienient...
You can pay $60 for a $13 head gasket if you like, but the ONLY difference between a "standard" automotive head gasket, and a "marine" head gasket, is the use of steel in it.
Fel-Pro doesn't use steel in their gaskets anymore either, so it's literally the EXACT SAME gasket.
Like I said though, do what you want. If not for people like you, the marinas wouldn't be in business to sell the rest of us the parts that really ARE "marine" parts...
