Automotive Ground Straps
tg3690
Most ground straps on trucks/cars are the flat, woven copper ones. Am in the process of checking/cleaning the grounds on my older RV and was thinking about replacing them with regular coated wire, maybe 10 gauge with weather proof ring terminals, instead of buying the woven copper ones. Is this a good idea or are the woven copper ones made that way for a reason? I'm not in the rust belt so there is not excessive corrosion.....just trying to make an improvement over the original ones. Have the wire and ring terminals on hand left over from other wiring projects. Thanks.
dingbat
The flat copper cables have a very large cross section with very fine wires to keep resistance to a minimum.
Will need a 2-4 ga copper wire to be comparable
tg3690
Guess my 10 gauge idea was a little on the light side.....so we are talking about battery cable size wire then. Well that's why I got on here and asked before making any changes. May just clean up the old ones real good and reuse them. Or buy original type replacements. Thanks for your input, sir.
tg3690
So just to be clear.....if I used 2-4 ga copper wire it would just be "comparable" and not better than the flat woven copper straps?
you realize that the flat woven ground straps are comparable to 4 gauge, however have 100% more flex. Not to mention are tinned copper for corrosion reasons and about 1/10th the cost of a jacketed cable.
i would simply buy replacements if yours are corroded or damaged
briangcc
These work, I have them in my 78 Trans Am when I re-wired it. They're also more flexible than 2-4 gauge battery cable as mentioned above.
tg3690
Makes perfect sense....that heavy wire is not very flexible and more expensive. Thanks for the input.
tg3690
Thanks for that link....they have exactly what I would need. (y)
dolluper
You must understand vehicle manufactors are cheap and want to save pennies anywhere... It always puzzles me why we are relying on a single ground wire instead of two or three even especially with computer controlled vehicles... Example one engine ground to frame is ridiculous it fails you have problems... So if you had two one could fail and you would still be problem free.
As you can tell l add grounds for further protection for flimsey vehicle wiring
dingbat
Because Best Engineering practice dictates one ground cable to prevent ground loops, especially when computerized system are involved
dolluper
Come on man we are talking vehicles 12or 24 DC volt systems... Not buildings running AC voltage 120AC 240AC or higher circuits
Apples not Oranges
dingbat
Apples not Oranges
Same principal applies to all electrical circuits.
Even more critical in DC circuitry…communications, processors, digital logic and control circuits, etc. because of the signal levels in use.
tg3690
The RV I mentioned above only had one original ground strap going from body to frame. I replaced it, and had thought about adding one or two more. Kinda glad I didn't now. (y)
dingbat
Ground loops probably account for 90% of all “noise” related problems reported in autos, boats and RV are a potential cause.
If one component on the loop is noisy and the return current flows through shared ground connectors, this noisy component is then the source for an introduction of noise to other components on the loop. This can be catastrophic with different analog or audio components along the same loop as a particularly noisy component.
dolluper
Funny a vehicle has numerous grounds which are seperate in series and parallel circuits with each component on the circuit with it's own dedicated ground.
