Avoiding lag bolts on engine mounts?
tpenfield
Re: Avoiding lag bolts on engine mounts?
My current and previous boat did not have lag bolts for the engine mounts. They were thru-bolted using special right angle brackets that were also thru-bolted to the stringers. A more complicated mounting system, but it is much stronger and avoids the rot-out issues of lag bolt mounting.
So, you options are to get specialized hardware, or fabricate a thru-bolt mount as show in a couple of the previous posts. You will want to make sure that any fabricated mount is beefy enough to handle the stresses that the engine will exert on it.
FWIW - I am not a fan of lag bolt mounting . . . you tend not to see that technique in offshore boats, which are designed to take a beating. So, there must be some method to that madness.
RacinRob
The only problem with thru bolting the side bolts is that if there is a problem I need to tear up the floor to remove engine etc. I did think of that though.
Thinking out loud here. Instead of the wood mount glassed in to the stringer, how about a thru bolted aluminum block to the stringer? Then bolt the engine mounts via tapped holes in the block. Hmmm
Tpenfield,
I've been on a lot of off shore boats and really like the Formulas. The fastest I've been was 135 GPS in an Eliminator Daytona race boat. The Skater I took a ride in was capable of 180, but we had no room to make that run and stopped at 120. I looked at a little older SS a few years ago but did not pull the trigger. My sister has a 382 Fastec. 1500 HP. Hauls ***. I was going to build the new engines for it but backed out because of her being family just in case something did not work out.
RacinRob
I liked outside the box thinking. You can never over engineer engine stability. When I'm doing 150 mph on the track, or 50 on my ski boat I want the same security. There is more stress in a boat hitting wake after wake than there is in any car application. My 750 hp in the race car is held in by basically 2 bolts. My engine/trans has 16 bolts holding it in the boat. There must be a reason for that. I see a lot of torsional stress that can happen in this style of boat. Some good ideas coming through, thanks.
