Avon Redshank
BonScott
I was just given one of these and so far am very impressed to say the least.No leaks, patches, etc. Guess it was tucked away for alot of it's time out of the box. My question is where could I find the motor mounts that were standard with it back when these came out. I've searched and seen some that look the part but would rather hear from someone in the know. I'll be using a merc 2 stroke on it. Also, is it possible to get a cert of origin so that I can register it? Thank you for your time.
TOHATSU GURU
Re: Avon Redshank
For Avon parts you would need to order them from an Avon dealer. The Certificate of Origin would have been with the first dealer who had the boat.
BonScott
Re: Avon Redshank
Thanks, that's pretty much what I figured I was just curious if the spacing between the collar mounts had been changed. I can't really find too much info on these things other than pics here and there. Thanks again for the heads up.
azlakes
Re: Avon Redshank
... hiya Bon;
Not sure if your referring to a transom mount for your O/B? Here is a setup I have and strengthened. You might be able to modify one to meet your needs. This is rated for up to 5 hp. I'm looking at a Suzuki 2.5 for it.
Cheers
TOHATSU GURU
Re: Avon Redshank
If it has the same mounts as the Avon Redcrest you can use the old style Achilles mount as well.
BonScott
Re: Avon Redshank
I'm checking on the similarities to the redcrest. I know they changed the tube diameter in either the redcrest, red "something", or redshank. azlakes thats a nice set up you have.I gave the serial number to a raft shop up here and they suggested that this one might be from 79 which boggles my mind. Thanks all again.
