Re: Axle Alignment
The perches are not really serving their purpose on my trailer because there are two metal plates between the axle and the spring in order to raise the fenders for bigger tires. I did have to drill a hole to accomodate for the perch in the bottom plate, however.
You drilled a hole in one plate to fit around the spring centering bolt head.
The head that should be in the axle spring perch.
The second plate just makes it worse.
You need to replicate the spring pack centering bolt head.
Lets assume the second plate (w/o the hole) is thick enough...........
Go get an allen head bolt of the proper head diameter same as the centering hole in the axles' spring perches. You want one that is only as long as the plate is thick.
Drill and tap where the centering bolt should be.
Screw the allen head bolt into the hole.
Weld the second plate to the underside of the first plate with the hole you drilled previously. Or you could drill and tap them and bolt them together with a couple of flathead allen bolts.
When your done the hole in the first plate will fit over the centerbolt head of the spring pack and the allen bolt head in the second plate will fit into the centering hole of the spring perch on the axle.
P.S. you might hane to grind the height of the allenhead bolt and or the diameter to fit good into the axle spring perch hole. In the past I have also used hexhead bolt and just grind the points of the hex off a bit to fit the hole diameter.
