- Joined
- Apr 17, 2002
- 71,182
Ayuh,... Ya know what it's like when you're stabbing an outdrive back onto the boat,+ You hear that solid metal to metal Clang, about 2" short of Home,..??
It's the Splines lining up with each other, rather than sliding together...
Bumping the motor is Out of the question, the key is 20' away....
Without a prop on the drive, turning the propshaft is Impossible....
Sooo,.... Yesterday, when that Happened,....
I dropped everything,+ went to wandering thru my piles of Junk,...
There I found an old prop hub I'd cut outa the center of an old prop to make a Propeller Plant Pot(ya, I welded a plate to the bottom to hold the dirt,+ water)....
I took the old hub,+ cut the aluminum away from it leaving Just the steel spline, covered with the rubber donut,...
Now,...
I can slide the spline over the propshaft,+ turn it by Hand, just that Tiniest amount to drop the drive in,....
I just can't believe it's taken Sooo many danm years to figure that 1 out......
I'll try to update this later with a Picture,......
Good Luck,+ Have a Great Day all....
Now,...
