Re: Back flushing?
About the only thing you could do is remove the hose for the telltale at the block to see if thats whats plugged, is the engine overheating, with a good impeller you can not back flush and I doubt if it would do anything any way. If its plugged up myou will probably have to remove the exh. plates and the cyl. block cover
