guitarkev77
Thread starter- Joined
- Jun 26, 2009
- 49
Hey guys,
It's been awhile since I last posted anything about my boat. It has been a crazy year, but now I am ready to get rocking on it again!
The boat is a 1967 Fiberform 16' runabout, which I have completely gutted, and removed the cap, deck, transom, and stringers. A little more grinding and I am ready to put it back together.
Long-winded introduction out of the way, I have a question for you guys.
My boat has 3 drain plug holes in the transom now. One in the splashwell, one above deck, and one below deck. My question is this: I am planning on completely glassing the deck on all sides to the hull and transom, and using two part foam underneath the deck (there was no foam when it came from the factory in '67). There is no bilge pump below deck, or gas tank, or ski locker. No water intrusion points, whatsoever. The only water intrusion point would be the below deck plug hole.
If this area is completely glassed in and water tight, effectively acting as one solid, structural member, is there a need for a below deck plug? Can I just do the topside and splashwell plugs, and eliminate the plug below deck?
I know that you guys will have some good info on why or why not.
Thanks,
Kevin
Thanks,
Kevin
