Backfiring 1971 60hp Evinrude solved...thanks iboats!
dfrants
the previous owner had removed the flywheel and did not tighten the nut down enough, the rotor loosened and spun, thus throwing off the timing and backfiring. the noch on the rotor is worn smooth, so i need to replace a rotor for a 1970-1 3 cylinder part number 392342 ? it is ring shaped. Don
