1994 5.0LMercuryAlphaOne
Thread starter- Joined
- May 18, 2008
- 32
Marina tells me they don't know why I continue to have the problem. When I first put the boat in water this spring it ran rough and backfired. Marina rebuilt carb. Continued to have symptoms: backfires around 3800 rpm, looses power when it pops, does not seem to want to "run out" smooth as in past (power), diesels at times after running and turning off without idling.
Took back to marina and they checked timing. Said they adjusted 2 degrees. Checked compression. Said this is not the problem or concern.
Marina said it could be the ethynol in the gas. I have ran tank empty and filled with non-ethynol gas. Same symptoms.
I believe this is a backfire from the carb and not an after fire from the exhaust as described in another post.
Man this is frustrating.
