Backlight on Tach stay on??
dspencer
I need help, how do you get the back light turned off on the Mercury/VDO Tach #79859020? Even after turning the battery switch off the back light stays on. The boat is a 2000 BW Ventura with a 135 Optimax.
thnx
roscoe
Re: Backlight on Tach stay on??
Well, since we can't see the wiring from here, it is hard to be specific.
But obviously, the wiring is not as it should be.
I would go through the entire wiring system and look for any abnormalities.
As a temporary fix, try removing all wires from the tach, except the signal wire and the ground wire.
ricksrster
Try wiring the tach light wire to the other instrument lights' wiring or the navigation lights.
WillyBWright
Disconnect all spliced-in gadgets and wire them separately from any wiring that has anything to do with the motor and gauges. I'm absolutely appalled by some wiring jobs I see when stereos and locators are installed by the inexperienced. The boat and motor circuits are separate to a degree, and many times the addition of gadgets compromises the separation if not done correctly. Out of sheer guesswork, I'd bet that you have a stereo with a memory that needs power all the time. Somehow that is backfeeding to the tach light.
Boatin Bob
That's nice but what was the fix?? I thought these boards were for sharing information??
dspencer
Just unplugging the Mercury harness conector to the back of the gauge reset the backlight and the mode button started to respond to:) I think this system is a
SC1000 SMART CRAFT. Who knows why the light stayed on I wish I could give a better explanation but thats all it took.
