redfury
Thread starter- Joined
- Jul 16, 2006
- 2,659
Hey all. I've been working a little on my 25hp Jonny ( 1990 ) and rebuilt the carb this winter. I'm getting a backfire and fuel pooling in the carb along with an idle that doesn't seem to want to change unless I just about close off the low speed circuit completely.
Anyway, I'm getting the impression that I've got a block seal that's going out. I'd really like to fix this motor, but I can't afford to throw money at the problem.
Time, I've got. Ability, I've got. knowledge is what I'm a little low on. I've got the manual and a compression tester ( basic ). I'm pretty sure I ran a compression test on it last year and it was fine. I'm going to pull the flywheel and see if any of the ignition components are showing any signs of wear before I go too nuts with this.
What I'd like to know is if there is a known seal that is common for leakage so I can get pointed in the right general direction.
Beyond that, I'd like to know what is involved in a crankcase pressure test...can I do it at home...what do I need?
