bad freeze plug
rinkerman
If I have a bad freeze plug in the back of the motor, do I need to pull the motor to change it? 350 mercruiser w/bravo3
mkast
Re: bad freeze plug
If access to the core plug is available, it can be replaced without engine removal.
If access is unavailable, engine must be raised or removed from hull.
Haut Medoc
Re: bad freeze plug
Most likely, from your previous description as to location, it is one of the core plugs located behind the flywheel....
The engine will have to come out to acess it.....
You should pressure test the block to see if there are any cracks.....
You might be lucky & it is just a plug....
Good luck!......:)
