isaacs
Thread starter- Joined
- Oct 15, 2013
- 153
Today, while underway, my 2002 5L engine started to stumble and hesitate. It got progressively worse over the course of about five minutes but I made it back to my launch without incident.
When I got home I was thinking of possible fuel problems and realized that I had not changed my fuel/water separator in several years. When I got home I changed the filter and when I dumped the old one out it looked more like water than gasoline; I wish I had saved it in a clear bottle so I could be sure.
I started the engine and it continued to stumble for about thirty seconds then it smoothed out and ran perfectly for about twenty minutes after which time I shut it off and patted myself on the back for fixing the problem. I'm thinking It had to run the bad gas out of the fuel line between the filter and carburetor before it got the good stuff.
Not knowing much about these filters I have a couple of questions. Is this typical? Do they simply fill with water 'till it starts getting mixed with the fuel and pumped into the carburetor? Would this make the engine behave as I have described? I should mention that this boat sees very little ethanol. I use E10 only early in the season when I know I will burn through it before it's time for winter storage. Would a lack of ethanol in the fuel cause any water to wind up in the filter rather than getting mixed with the gas?
One final question. Is there another filter at the carburetor like the old GM cars used to have?
Thanks in advance and sorry to be so long winded! Bob
