Hey guys I am having a problem with my 2008 Q4 Tahoe not starting. I replaced the starter but where I went wrong was I got the new starter at O Rileys ( I know bad mistake :facepalm
But the new starter / solenoid only had 2 main post one where the old one had 3 (one for the postive battery lead w/ 90 amp fuse and then one for a purple lead and one for yellow lead) Well on the new solenoid I just put the purple and yellow lead together. The boat started and after 5 seconds made a squealling noise and died. Now the when I turn the key NOTHING happens.
I took the O Rileys starter off and took it bad and ordered a marine grade starter / solenoid for the local boat shop. But that starter on and still NOTHING. I did a little research and found out that there is a little white box that connects to the same post at the battery lead and its suppose to be a 90 amp fuse? Do you guys think I might have blown that fuse and thats why i'm not getting nothing? thanks for the help guys
David
David
